Just got done with "Daniel in the Lions Den" finally. Over the holiday I came out every day to send out a cut path to get it done. On the last tool path I had to separate the cut job into 3 separate cuts. Reason is my CNC only has 34MB of RAM and the whole cut file would have been like 70MB. Oh well, you work with what you got! Prepin to paint right now.
Best
Vic
Daniel in the Lions Den- Carved
- Model of CNC Machine: 5ft x 8ft 11"inch Z axis 24k-rpm
http://www.rev-art.comKeep those in your life that charge your battery, not drain it.
Re: Daniel in the Lions Den- Carved
Nice Job, what is the size, hard to tell with nothing to gauge by
Dana Decker
Aspire 8 something
CaMaster Stinger I
Aspire 8 something
CaMaster Stinger I
Thanks! Its 41" tall by 24" wide by 1.625" thick. It took a very long time to carve out. Somewhere around 35hrs.
Best
Vic
Best
Vic
- esteeme1
- Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Vic,
Nice job. How are you going to finish it?
Jim Darlas
"Can Do!"
"Can Do!"
Well after the black primer I will use a cheap horse hair brush to just stroke over the piece with a silver paint. Barely hitting the piece will still allow the primer to poke through and give an aged antique-i look. Kind of how I did the tiger piece below.
Best
Vic
Best
Vic
- zeeway
That's great detail. Tell us some details about how you broke up the file, tools used, etc.
Angie
Angie
Sure thing Angie! Here is a few pics that should tell the tale!
The first pic show the vectors. One vec around the whole thing which was used for the roughing path and the first finishing path. The other vecs are for separating the detailed finishing paths for all three of them.
Vic
Vic
