Lion Carving with Metal Coating
garylmast
Post by garylmast »
My latest carving that I thought I would two-tone it with the powder metal coating I’ve been doing in previous projects, Bronze and Stainless Steel. It looks a lot better in real life than what’s in the pictures. I carved it using MDF. Size is 18” x 7” x 13” tall.
Gary
jfederer
Model of CNC Machine: CanCam D23M
Re: Lion Carving with Metal Coating
Post by jfederer »
Nice work Gary! I've been climbing the Aspire modelling learning curve this past week, I now have a clue how much work you put into this! How many slices/segments?
Joe Federer
www.fabrikisto.com incl. Tailmaker software
www.federer.ca
garylmast
Post by garylmast »
The Base was three slices, however I merged them together, so It was one cut on 1-1/2" thick material. The head was one slice on 2-1/4" material and the body was three slices on 3" thick material. It involved extra-long mills, so probably a better way would be more slices on thinner material. Of course, most cuts were double-sided. Although I used Netfabb for the slicing, everything could have been done in Aspire. Thanks for looking.
Gary
Creation in Wood
Model of CNC Machine: Legacy Maverick ATC 4x8 CNC
Post by Creation in Wood »
Great carving Gary
Thank You
Wayne Locke
Model of CNC Machine: Shopbot
Post by Wayne Locke »
That looks great. Did you spray the resin metal mix? How much metal did you mix with the resin?
garylmast
Post by garylmast »
The mix is 3 to 1 metal to resin. This model took 300 grams metal to 100 grams resin, using a $15 scale I got from Amazon. After the resin is set, usually the next day, I take steel wool to buff off the resin until the metal shows through.
Gary
Wayne Locke
Thanks for the info. Did you spray or brush?
garylmast
Post by garylmast »
I have a cup gun with an oversized nozzle (2.3mm). It's similar to one you buy at Harbor Freight for 1/3 cost but only a 1.4mm nozzle. The body of this model I sprayed, but while the resin was still wet, I brushed the stainless-steel mix using just a small flux brush. Needless to say, you can do either way.
Gary
Wayne Locke
Thanks.
