Bowled over
rtibbs
Model of CNC Machine: Shopbot desktop
Bowled over
Post by rtibbs »
This is my third bowl and made it from Canary Wood. 5 1/2 inches in dia. x three inches tall finished with clear Danish Oil.
After I finished i realized this would have been a good candidate for resin inlay.....maybe next time.
At least this one didn't have a hole through it :mrgreen:
Also when Randy did his demo he glued plywood tabs to the block and used them as hold downs. The turning blocks i use have a wax coating on them to prevent cracking etc. Tried sanding the areas where I would glue the "Tabs" however, they wouldn't adhere very well.
I cut slots in both sides of the blocks and used toe clamps to hold the block in place.
Re: Bowled over
Post by mtylerfl »
Nice work, Ron! I’m bowled over, too!
carvebuddy.com
Re: Bowled over
Post by scottp55 »
LIKING it Ron! :)
Boy, you must have Safe-Zs/Home Position Z/ and Shopbot VC setting at Low numbers!
Glad you didn't get another "Holy" bowl. :)
Pretty piece!
"When in doubt....Zero it out!"
anon saying
rtibbs
Re: Bowled over
Post by rtibbs »
Scott
Balancing my max Z, bowl height, long cutter length, collet nut diameter, spindle mount plate protrusion, safe Z of .125 I call it my “Pucker factor” when I press Start Cut. :mrgreen:
Measure twice, cut once really comes into play....
Re: Bowled over
Post by scottp55 »
Yep Ron,
Had a few cuts where the collet nut went below the surface...always nerve making!
Quite a few branches you have to play with Home Position and vector starting points
to make sure the cutter gets there Before the Z carriage plate or dust foot plexi.
Does make you tense up before pressing Start, with finger ready far a fast Stop!
Nice job!
anon saying
jay pieper
Model of CNC Machine: laguna swift 4x4
Re: Bowled over
Post by jay pieper »
Ron....
Very nice job with the bowl turned out very well.
Have been working on this with the molding toolpath and
am close to making a run at it. Have to do a little more
tweaking on the design for the bowl width, yours looks
very pleasing to the eye.
