Need some help!!!
Re: Need some help!!!
Joe did a great job on this but I'd like to see how it could be done only using Aspire.
- joecnc2006
The last post with the set of screen shots (three posts up) was done all in aspire with the over lapping components to make them blend in together.Phil wrote:Joe did a great job on this but I'd like to see how it could be done only using Aspire.
Joe
Joe
http://www.joescnc.com
Joe
I thought you created the ring in Solidworks.
- joecnc2006
The 1st set of instructions was with the STL ring file. The posts are not numbered on this forum, but i believe it is the 11th one down, the 13th, two after that shows the one all done in aspire.Phil wrote:I thought you created the ring in Solidworks.
Joe
Joe
Joe
Joe, I'm still scratching my head. I know which post you are referring to but I can't figure out how you created a ring shape. Was it a two rail sweep?
