I am not sure if I am doing something wrong or maybe what I am attempting is not possible. I am trying to use the Rose-A and make it 1.5" tall. When I do this the petals look great but the leaves look fat, so I try to fade from the center out, but it only works on one side. Is there a way to do this all the way around the rose so the leaves fade to the outside?
Mike
fade more than once
Re: fade more than once
Maybe fade---save---fade---save ??mpjensen wrote:I am not sure if I am doing something wrong or maybe what I am attempting is not possible. I am trying to use the Rose-A and make it 1.5" tall. When I do this the petals look great but the leaves look fat, so I try to fade from the center out, but it only works on one side. Is there a way to do this all the way around the rose so the leaves fade to the outside?
Mike
when I do that it seems to undo the first fade and then do the second.......
- Turtle49
First, fade only works in a linear fashion, one direction at a time.mpjensen wrote:when I do that it seems to undo the first fade and then do the second.......
I think what CRFultz was referring to, is apply a fade to a component. Then copy that component to the working model and save it as a new component. That will allow you to apply another fade.
Does that make sense?
Tim
Tim Hornshaw
www.HornshawWoodWorks.com
I got it. Thank you both!!! It is Monday and I am a little slow.
