help for new balde in tools aspire
gcioffi
Post by gcioffi »
hi
sorry how can I use this tip in exactly?
not here measure for t'is blade
mark296
Re: help for new balde in tools aspire
Post by mark296 »
That looks like a veining bit used to put small vein lines in your design.
Tony Mac
Vectric Alumni
Post by Tony Mac »
Import image into Aspire / VCPro
Draw vectors over the top of the image around the cutter
Scale the vectors so the shank = the actual diameter of the cuter ie 3mm / 6mm
Measure the angle and actual tip diameter.
Your photo is pretty good so you should get a reasonably accurate result and
you can then create the appropriate cutter in the Tool Database.
Tony
RoutnAbout
Model of CNC Machine: 18 x 24 Desktop
Post by RoutnAbout »
Tony Mac wrote:Import image into Aspire / VCPro
Tony
Great Tip Tony...
Thanks...
Roll of Honor <-- Never Forget
________
Don
mark296
Post by mark296 »
That is a neat trick. Thank you Tony.
gcioffi
Post by gcioffi »
sorry tony image not here in scale
possible chek correct measure ?
I do not understand how
gcioffi
Post by gcioffi »
ok
degree is 175
have add blade
velleca55
Model of CNC Machine: BF20 CNC Optimum - ProxMF70 CNC Usovo
Post by velleca55 »
175 ? ... something wrong !
Perhaps 15° is the corret misure. I made a misure on screen.
gcioffi
Post by gcioffi »
correct is 84,90 o 85 degree
blade image
velleca55
Post by velleca55 »
Perhaps I'm wrong bur I think 15° is the correct total angle.
mark296
Post by mark296 »
If that is a .25 shank then it's 6° on each side.
gcioffi
Post by gcioffi »
sorry
tony write
velleca55
Post by velleca55 »
mark296 wrote:If that is a .25 shank then it's 6° on each side.
Ok the total is 12° not 15° ... :oops: ... I take measure on screen only to show the exaggerate of 175° ... :wink: ...
Greasetattoo
Post by Greasetattoo »
That looks like a Beckwith.
I just use the standard ball nose.
velleca55
Post by velleca55 »
Yes I think is the better way, but in my TRIAL version of Aspire I don't find in the tool library the "Radiused Engraving" ...
If the work/model have some height perhaps is better put like "Rounded Engravig", but in any way is a ballnose and normally is used to finishing tool paths and for that like a ballnose is a good way .
