hi
I can not work with sculpting.
design work as we see, but when I open my SCULPTING disappears 2d1 / 2.
What did I wrong?
SCULPTING
Re: SCULPTING
Well....let's see, Before you tried to sculpt, did you copy your components into the working model?
In order to sculpt you must have the components in your working model.
In the component manager, at the very bottom, is a button to copy the item into your working model.
Hope that solves the problem.
Chuck
Chuck
Re: SCULPTING
ho thanks you
è fantastico ok
è fantastico ok
- Wemme
Re: SCULPTING
I must not be seeing the button ??
I've imported a bit map then converted it to a 3d component and it's listed under the component view f8,
but can't seem to figure out how to work on it to smooth or sculpture it.
any pointers?
Regards
Bart
any pointers?
Regards
Bart
Re: SCULPTING
Bart you might want to copy the component into the working model, then you can sculp or smooth. You can do that from the Component Manager. Select the item or items and then click the button at the bottom.
Chuck
Chuck
- Wemme
Re: SCULPTING
Thanks chuck,
The thing that got me confused was that my part was listed in the model but when i did click copy into model it added to the model making twice as thick,
But at least now i can mess around a bit more with aspire I've just installed the DVD so will go through the demo videos now.
Regards
Bart
Regards
Bart
Re: SCULPTING
No problem, one thing to add is the Component manager will only list the items that would be classified as a Component. Think of it has a parts drawer that you can pull from. You take a item from there and copy it and place it into the working model and then put it back into the parts drawer. Now you have two items showing, that is why what you see has gotten twice as thick. After you copy from the Component Manager, uncheck the item in the list and you will only have the single "copy" to work on in the working model. When you are done with the working model, you can make it (with the changes) into a new component to continue on with the project. I save as i go along and close out any thing that is not needed. I have found for myself, having only a few items to work with keeps things simple. I have begun to use sketch like James recommended, to keep track of what I'm doing.Wemme wrote:Thanks chuck,
Regards
Bart
Chuck
- Wemme
Re: SCULPTING
Thanks for the information chuck,
I Think i need to do some more reading.
Regards
Bart
Regards
Bart
