If I want to mill a pocket with a smooth bottom finish I can (within the Pocket Toolpath options) set a shallow depth for my final pass. Trouble is I can't do that for clearance passes within V-Carve toolpath and I'm getting a rough "bottom" to these areas. Wasting a lot of time sanding them out and it's often difficult depending on the final shape and dept of the cut. Any way to improve this? I'm using a two flute down-spiral bit.
thanks
Clearance passes in V Carve toolpaths
- Jerry In Maine
- Model of CNC Machine: CNC Router Parts CRP4848
I'm just a number in a great design
- gkas
Re: Clearance passes in V Carve toolpaths
How big is your Vcarve pocket??
- TomWS
- Model of CNC Machine: OB Lead 1010, Mach3; OB C-Beam 1060 grbl
Edit Passes allows you to set the cut depth of the last pass. Doesn't that do what you want?
No "Edit Passes" in V-Carve / Engraving Toolpath.
How about setting the flat depth a little shallower then create a second toolpath to the final flat depth. The second toolpath's tools can have their Pass Depth parameters set to your flat depth so that they don't "air cut". Same procedure as you're doing for normal pocket toolpaths.
- FixitMike
The VCarve Toolpath does not have an Edit Passes option.
- FixitMike
The VCarve Program and the VCarve Toolpath having the same names often causes confusion. Been there, done that.
