Good afternoon.
I am making a clock to sit in a 400mm long x 40 mm thick a 50mm wide base
The clock is 400mm in diameter.
I wish to have it sit in the base by 12mm,
How do I draw the slot for the clock to sit in to follow the 400mm curve and then machine the curved slot, as per my drawing.
I trust that someone will be able to assist me
Thank You
Barrie
Drawing and machining a curved slot
- adze_cnc
Re: Drawing and machining a curved slot
One potential quickly drafted and toolpathed solution is presented here (recalculate the toolpath as it is not calculated for a smaller file size).
- clock-base.crv
- VCarve v9.519 file
- (25 KiB) Downloaded 74 times
- SteveNelson46
You could also do this with a moulding toolpath.
- Clock base.crv
- (156 KiB) Downloaded 67 times
Adze
My thanks to you for your very much appreciated file.
It looks like it will work very well.
Regards
Barrie
Regards
Barrie
Steve,
I also thank you for you excellent file
It is so good that there are people in the forum that can and are willing to assist.
Regards
Barrie
Regards
Barrie
