Hello,
I have used Aspire to edit a photo, and copied cut and paste parts of the image. I did this to change the image from a rectangle to a circle to fit the circular material. Now I have multiple BMP "parts" that I am unable to export. When I do export the only part that is exported is the circle vector. I am using Aspire as a photo editor and it worked well but I am unable to weld the "parts" nor am I able to export the edited image.
Question 1. How do I or can I merge the parts to create one image. if not
2. How can I export the entire image ( I have selected all the parts)?
Thank you
Exporting
Re: Exporting
You can't export a bitmap from Aspire at that level. Only once it's been toolpathed or made into a component both of which wouldn't apply here.
You need to use a proper photo/picture editing program really but I guess you could use a snipping tool to capture the bitmap you've made.
Re: Exporting
Ok, I though I would try.
