For instance if I have a circle this toolpath a color can be assign to it, but what about inside the circle? Can this be done? How?
Sincerely
Luis
How to assign color inside the toolpath
Re: How to assign color inside the toolpath
You have to create a dummy pocket toolpath to remove the material inside the circle and set the colour on that toolpath.
The “dummy” toolpath, for display purposes, that Adrian mentioned could have a depth set to 0.01mm (or 0.001 inches). This is so that the colour of the cut will register but the circle won’t noticebly change thickness.
Good Tip, thanks you very much guys.
