Scalloping technique
Hello all. I have seen some older post as it pertains to scalloping techniques but, with updates and advances in Aspire, I was wondering if anyone had any good thoughts on how to create a scalloped pattern along a given path? Any help would be appreciated.
Re: Scalloping technique
Even though the posts and videos are older the technique remains essentially unchanged.
- ohiolyons
I suggest practice, practice, practice.
I just did a lot of scalloping so four models would have the "same' scalloping pattern.
Version 10.5 allows you to save your settings file name and use those settings across all your files.
I found this to be very helpful.
My previous scalloping effects very less than satisfactory, but I really like the results I have gotten.
John Lyons
CNC in Kettering, Ohio
- ohiolyons
settings that worked for me
I would do one side and save so if the next side was bad I didn't looose everything.
John Lyons
