Hello everyone
Question - What is the shortcut to vector alignment in node editing? Yosef
node editing
Re: node editing
The standard vector alignment tools work when you're in node edit mode. There are no shortcuts for them in either mode.
- SteveNelson46
Re: node editing
Not sure I completely understand your question but you can align nodes using the keyboard short cut keys. Select each node by holding down the shift key and then press "X" for vertical alignment or "Y" for horizontal.
