Laser Etching Tile
gkas
Laser Etching Tile
Post by gkas »
I have the Axiom 4.2 watt laser (made by J-Tech). I can't change power on-the-fly, so I'm pretty much locked in to single power etching.
Every once in a while I play around with lasering different materials. I had been planning on test lasering a painted tile. Then I came across this video the other day. Zinc coating for diode laser "etching" glass & tile. Water clean up. High contrast. https://www.youtube.com/watch?v=LR9CDz8 ... WL&index=9 He touts using a Cold Galvanizing spray paint prior to lasering. Cheap enough to buy a can.
Here's what I got:
Galvanize Spray, One Coat
The single coat with lasering when dry to touch came out best. But, not anywhere near as dark as the video.
Brown Spray Paint, Two Coats, Cured
I like lasering on the brown painted ceramic to reveal white. Any ideas for clear top coat? I'd like to use them for trivets, but I'd like them to hold up reasonably well.
Brown Paint, Melted with sprayed with clear topcoat.
This was my first try. I lasered the brown paint, then sprayed with a clear coat. INCOMPATABLE. The brown paint dissolved. When I wiped off the brown, it filled the etch. I guess the laser did etch the glaze. Anyway, the fill looks pretty good.
Re: Laser Etching Tile
Post by highpockets »
Nice work Gerry, hoping to get my laser setup one day :lol: :lol: :lol:
wilkigr
Model of CNC Machine: Sienci Long Mill
Post by wilkigr »
I use a water-borne poly recommended for floors. I use a Critter spray gun to apply it. Two coats seems enough. Friends and family have been using them as coasters and they still look fine.
gkas
Post by gkas »
wilkigr wrote:
Wed Apr 28, 2021 12:46 pm
Thanks, I'll look around.
wood_fly
Model of CNC Machine: Axiom AR8 Pro V5+Jetch Laser+Rotary
Post by wood_fly »
That's nifty! Thanks for sharing. Got a can coming my way...
Tim
Tailmaker
Post by Tailmaker »
Tabletop epoxy pour might look good and needs only a single coat.
Garyht
Post by Garyht »
Nice work Gerry. Have you tried etching slate yet? I am experimenting now.
Tex_Lawrence
Model of CNC Machine: Shapeoko3XXL; JTech7W; V-CarvePro 12.004
Post by Tex_Lawrence »
gkas wrote:
Wed Apr 28, 2021 4:20 am
... He touts using a Cold Galvanizing spray paint prior to lasering. Cheap enough to buy a can.
All you need is Rustoleum paint. Most of their sprays have "Titanium Dioxide" in them. It must make the white whiter, because the white seems to produce a darker leftover etch.
You can feel this etch on the tile. It is not the same as some are doing with grayscale images, though. It is good for lineart images.
A single coat is sufficient and wait 20 minutes for drying to touch. Use mineral spirits and acetone to clean the tile back to its shiny surface.
Quick and easy.
Tex — Crooked Wood Products
gkas
Post by gkas »
I'll have to dig out some of the tiles and try agian. It got put on as back burner to complete other projects.
tnx
Gerry
