xoneeleven wrote: ↑Mon Oct 26, 2020 2:58 pm
The original toolpath setup was:
1: Roughing Toolpath - 1/4in end mill
2: Finish Toolpath - 1/8in tapered ballnose
Total cut time = 10:06:04
The new toolpath setup we are considering:
1: Roughing Toolpath - 1/2in ballnose
2: Finish Toolpath 1 - 1/4in ballnose
2: Finish Toolpath 2 - 1/8in tapered ballnose
Total cut time = 07:07:53
They key here is that the 1/2in ballnose removes material faster than a 1/4in bit.
OK, sure, that does make sense.
Still there are many ways to skin the cat.
Scott55 is really good at what he does and Scott makes some really awesome and small stuff. If you are using a 1/2 ball mill for roughing I think your project is large, or at least somewhat large.
I have used 2-3 finish toolpaths like Scott is telling about. That IS a valid approach for sure and a good one at that.
The Amana cutter is a good cutter, and I think can do the work to finish without the intermediate cutter, even cutting Cherry. Still depends on the machine and workholding.
So, on the 1/2 ball mill tool path, you can adjust feedrate, Depth of cut and stepover to save more time, then go onto the 1/8 TBN finish toolpath without the intermediate toolpath.
Maybe you did already, but can you tell us more about speed, feed, machine, size of project, and maybe a picture of the project?
edit in - OK I see the image.
Yes, I can see some significant ways to save a lot of the time in that project.
You do not need the 1/8 TBN on the entire project. The individual details can be done separately and the base can be done with a different cutter. Vector bountaries can isolate the details so they can be cut seperately, and allow a different cutter to cut the base. The 1/2 cutter can certainly be make to be cutting more efficiently.
What is the outside diameter, and what machine, spindle are you using.
