Model Surface Profile using a line
RoutnAbout
Model of CNC Machine: 2004 48x96 PRT 5hp Spindle
Post by RoutnAbout »
I'm using Aspire Ver8.5.
There was/is a feature that if you'd lay/draw a straight line across a model like you were going to split the model or component. Instead of it splitting the model it gave you the profile of the surface along that line.
I've looked through the tutorial but haven't found anything.
Thanks in advance.
________
Don
FixitMike
Re: Model Surface Profile using a line
Post by FixitMike »
If you profile along the line with a toolpath that cuts the full depth of the material, and then in the preview, double click on the piece you want to disappear, you can see the section cut.
Post by highpockets »
gkas
Post by gkas »
In the Measure/Inspect dialog, there are two checkbox options; 'Span/Contour Properties' and 'Model Cross-Section'. One of these is what you're looking for.
RoutnAbout
  • Thanks John, that's exactly what I was looking for.
  • Thanks gkas, I knew it was some where.
  • I appreciate the attempt Mike.
Am creating/routing a paint mask for a part that on the 2020 new mid engine corvette.
Have landed a 6 year contract. It's gonna be a nice gig.
Thanks for your help guys
________
Don
