Filets
adirondak5
Model of CNC Machine: CAMaster Stinger I WinCNC Aspire 8
Filets
Post by adirondak5 »
Is there a way to create fillets with Aspire on acute angles ? Or is it just a 90* angle option ?
Mike-S
Re: Filets
Post by Mike-S »
If the vectors are straight and connected, you should have no problem with acute angles.
joeporter
Re: Filets
Post by joeporter »
Fillets or radiuses can be added interactively at points where any two straight lines meet......joe
adirondak5
Re: Filets
Thanks fellas , seems I was using to big of a radius on my fillets when I tried this , now that I have them properly sized it works just fine .
FixitMike
Re: Filets
Post by FixitMike »
Note that if there is a node (other than the corner) on either of the lines that the fillet would eliminate, the tool will not work. Also, if you already have a profile toolpath for the lines with tabs, recalculating after adding a fillet may cause the tabs to change location.
adirondak5
Re: Filets
Thanks Mike , was not aware of nodes causing the tool not to work , I'll keep that in mind
