Insert Tab A Into Slot B
zeeway
Post by zeeway »
More and more of my projects these days involve making parts that must fit into each other. In making chairs and stools very often there is a pocket or a slot that mates with a tenon or a shaped end of a leg.
Too often, in my impatience, I remove the female piece from my machine, only to find I must spend a lot of time with chisels or files or sandpaper to make the parts fit.
In my designs, I may leave a theoretical clearance of .010 inch per side. But in real life, even though my machine is calibrated as well as I can adjust it, I find that pockets and slots always cut to the small side, while parts machined on the outside always cut to the large side. My guess is that my .250 cutter is a bit undersize, or flexes, or something, making the size less than perfect.
So, my tip to myself and others is to keep that female part attached to your machine, until you have checked the fit with the mating part. It is certainly much easier to recut a fit dimension on the machine than to do it by hand.
How do you address this issue?
Angie
Turtle49
Model of CNC Machine: 4' EZ-Router and Blurry customs SK25
Re: Insert Tab A Into Slot B
Post by Turtle49 »
I have to ask. Do you use climb or conventional for your finish cuts?
I have found that when I select conventional for my finish cuts I get a more accurate size. The climb cut tends to flex the bit away from the vector. While the conventional will load and flex the bit parallel to the vector.
Perhaps that is affecting your results.
Tim Hornshaw
www.HornshawWoodWorks.com
cac67
Model of CNC Machine: Joes Evo 3x2
Post by cac67 »
Under sized bits are very common. I used to measure the bit I was going to use and put the actual size in before calculating the tool path.
4DThinker
Post by 4DThinker »
When it matters, I'll take my digital caliper to the bit I intend to use. Onsrud bits will usually be exact or very close, but bits from anyone else can vary wildly.
4D
zeeway
Post by zeeway »
I will admit that I have not paid any attention to whether the cut was climb or conventional. I'll give that a shot as well as measuring the bit. Thanks for the help. But even with that, I will still proceed with caution.
Angie
Post by mtylerfl »
zeeway wrote:,,,
Angie
Hi Angie,
Our good friend Tim Merrill has always advised this - i.e., cutting the male part first, then cut the female part, keeping the female part attached to your spoilboard to check the fit of the two. If the male part fits too tightly, then you can easily modify your original file, then recut the female pocket/dado/slot by a tiny offset amount until it does. This is just one of the many, many golden nugget tips I've/we've learned from him.
Another great tip is one I learned from Gary Campbell for determining if, or by how much, an End Mill bit is undersize. He recommends performing a plunge cut (drill) or slot cut with say, your 0.25" EM in some scrap and measuring the HOLE (or SLOT width) itself. The size of the real-world cut is often a better determinant than just measuring the bit alone.
carvebuddy.com
zeeway
Post by zeeway »
Thanks for those comments, Michael. Maybe I should print those out and keep them posted in my shop, so I won't forget. And thanks to Tim and Gary (once removed).
Angie
