Go to metallic finishes
hdtheater
Model of CNC Machine: CNC RouterParts Pro 48x96
Post by hdtheater »
I have been doing some searching on different metallic finishes.
I have used rub n buff for some small stuff and metallic finishes from a rattle can over the last few years, but it just doesn't come to the level of quality I want anymore. Maybe it's a sign I am getting better at this. :)
I am leaning towards buying some samples of the modern masters brand to play with.
For those that have used them, is there a particular color you go to for bronze, copper, pewter, etc...
Is there another brand you like over modern masters?
-Eric
dealguy11
Re: Go to metallic finishes
Post by dealguy11 »
I've had much better results with SculptNouveau
Steve Godding
Post by Rcnewcomb »
Another vote for SculptNouveau It is very easy to work with, cleans up with water, and is designed for outdoor applications.
10 fingers in, 10 fingers out
another good day in the shop
hdtheater
Post by hdtheater »
What type of materials have you used it on? I haven't graduated to HDU yet and still work mostly with foam and MDF.
Do you prefer to spray or brush on?
-Eric
-Eric
bluridg
Post by bluridg »
I've used it on mdf and pine I seal w/ shellac then apply two coats of base color any way you want. application of the tarnish depends on the look you want. some of the sculptures shown were probably sprayed then wiped or sanded off the high points. I've started applying the tarnish with a sponge giving a doppled effect. ted
Post by Rcnewcomb »
I use it on MDF with Zinser primer underneath. Type B is less expensive and easy to experiment with. Type C is a 2 part mixture that yields a harder surface that can be shined to a certain extent.
dealguy11
Post by dealguy11 »
I generally spray it on. That way I don't see the brush marks when I polish some of the tarnish off once it dries. For certain kinds of metals, the brush strokes might be ok, but I think spraying better simulates the surface of metal.
Steve Godding
Post by Rcnewcomb »
Steve,
For spraying do you thin it with water? What ratio?
I've always been a foam brush guy but sometimes the brush marks still show up.
dealguy11
Post by dealguy11 »
Last time we sprayed it was a large piece so we used an airless sprayer, which didn't require thinning at all. In the past, I have thinned with water. You have to use a large aperture because the paint does tend to gunk up the sprayer.
Steve Godding
hdtheater
Post by hdtheater »
Could you use an HVLP gun if thinned?
Appreciate the feedback. I have a run of plaques to do and while I won't have to finish them, I want to see what it would take if I did. I may want to add finishing the next time in my bid.
-Eric
dealguy11
Post by dealguy11 »
I've never had much luck spraying paint with an hvlp gun. I'm told there are some who make it work by mixing windshield wiper fluid as a thinner and wetting agent. I've had better luck with a regular sprayer.
Steve Godding
