fonts
j.r.teichman
fonts
Post by j.r.teichman »
I have had request for cutting individual letters out of mdo plywood do any of u folks know of a particular block type font that is best suited for this the lettering will be 6 in. tall and 1 in. thick, customer will paint. should i be looking to buy more professional font file?? this is going in hi traffic mall/ shopping area so i want to impress.
FixitMike
Re: fonts
Post by FixitMike »
Wayfinding was developed for making traffic signs so they could be read without mistake. Not fancy, but very practical.
Notice to dogs.crv
(1.21 MiB) Downloaded 168 times
Re: fonts
Post by Rcnewcomb »
Check out Letter Head Fonts: ->Link
10 fingers in, 10 fingers out
another good day in the shop
Re: fonts
Post by martin54 »
As Randall has already said you wont go far wrong with a letterheads font & the other advantage of actually buying fonts is it makes it more difficult for anyone copying your work.
With any job for a shop front I photograph the shop, scale the photo up to correct size & then place the letters on at the requested size to ensure they fit OK. Some people forget that the length increases as the letters get bigger :lol:
How are you going to fit the letters & how are you going to ensure they are aligned & spaced correctly? As a signmaker I make a paper template on the plotter which makes it really easy.
Warped Mind
Re: fonts
Post by Warped Mind »
I have found www.dafont.com a very use full web page for adding fonts.
SawdustandSmoke
Model of CNC Machine: home made
Re: fonts
Post by SawdustandSmoke »
I like to go to a place called dafont, best thing about it is that you can type in whatever you want in the preview box.
champawm
Re: fonts
Post by champawm »
I would like to know with-in a paragraph, is it possible to change a single word font, to high lite that word? If so how do I do so???
Re: fonts
You would have to do it as separate text items (one before the word, the word itself and one for after) as a text block is the same font throughout.
If you just wanted the word bolder you could convert the text block to curves and then use the offset tool to make the letters in the word bigger.
