Sanding 3d carving
quardo
Sanding 3d carving
Post by quardo »
Just wondering what methods/tools people are using to do finish sanding on 3d work? I just completed two 4 foot mantle pieces with a celtic weave in them. I am pleased with how they came out, but I am struggling with how to clean the piece up for finishing. I've included a picture of what I'm talking about.
sawmiller
Model of CNC Machine: joe's rack and pinion hybrid
Re: Sanding 3d carving
Post by sawmiller »
those sanding disks that micheal uses work great, you just have to be gentle with them as you can wear them out fast.
look up one of the mothly projects , he lists the source for them in almost every one.
also have used a burr bit in a dremel to undercut and hog some bad areas out.
dan
In the heart of Tn
mezalick
Post by mezalick »
Google "Mop Sander"
It works very well on 3-D models
http://store.carvewright.com/home.php?cat=299
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
vfauto
Model of CNC Machine: Legacy Artsian 72"
Post by vfauto »
I just got this for Christmas. I have not used it on a project yet but I tried it on some scrape. Seems to work well so far.
http://www.proxxontools.com/store/pc/vi ... ategory=28
I also use the these.
http://stockroomsupply.ca/shop/sanding-mops.html
http://www.theonlinewoodshow.com/show/c ... 0102&cat=2
Thank You
Frank
mikeacg
Post by mikeacg »
Frank,
What are the green wheels? Source? They look very interesting!
Mike :)
COWBOY1296
Model of CNC Machine: SHOPBOT BUDDY PRS 32, 4 FT PWR STICK
Post by COWBOY1296 »
I use a sanding mop and the pen sander as well. My first sanding mop was 220 grit. I did not think that was rough enough so now I am at 180 which should be fine. With the pen sander 220 was way to fine and now I use 150. Having a needle file helps too. I cant honestly say that I have ever done a perfect sanding on 3-d but do the best I can. There are just some areas that you can not get to.
Phil
Post by Phil »
I usually start by vacuuming off any dust, then scrub with a toothbrush, vacuum again.
Then I apply a very thin coat of water based polyurethane, this stiffens the fibers and makes the fuzzies easier to remove.
Next I use a dremel tool with red 3M scotch brite discs that I make by cutting them out with a 1 1/2" hole saw. The discs work well and they are cheap. For the chatter marks I have a Flexcut carving gouges that match the diameter of the cutter used on the router. This all goes pretty quickly.
Phil
Post by Rcnewcomb »
For future reference, steep "walls" tend to show tool marks. You can reduce or eliminate these by applying a draft to your component. It will look better and require less cleanup.
10 fingers in, 10 fingers out
another good day in the shop
rsetina
Model of CNC Machine: Shark HD 2.0
Post by rsetina »
What do you mean by a draft? I haven't heard that term before.
Rick
Shark HD 2.0
zeeway
Post by zeeway »
rsetina wrote:What do you mean by a draft? I haven't heard that term before.
Third icon on third row modifies your model so that any walls (straight up-and-down surfaces) become tipped by a few degrees to help the machining process...I think the term came from making models for casting - they must have "draft" so the model will release from the mold.
Angie
zeeway
Post by zeeway »
Actually I guess it affects all "walls"...the 90 degree vertical ones as well as the rest.
Angie
ChrisInEstes
Post by ChrisInEstes »
I'm just posting in order to subscribe to this thread. I need a better way to clean up reliefs, too.
Thanks!
Chris
mezalick
Post by mezalick »
A word of caution about the "Draft".
It will apply that new slant to any and all vertical "walls" that are shown in the 3D view and create a new component from them.
So, if you have three components shown in the 3D view and you want to add a "draft" to only one , you will need to hide the other two components or you will get a new component made up of the existing three components.
It will not delete the original three but you may not get the effect you're looking for.
Michael
Michael Mezalick
mm@mezalick.com
rsetina
Post by rsetina »
All great info guys. Thanks for the replies. I'm still new to the aspire program and you all help me learn things I wouldn't normally use.
Rick
Shark HD 2.0
