Slicing and gluing
angelosart
Model of CNC Machine: Shopbot Buddy32
Slicing and gluing
Post by angelosart »
Any tips or tricks to gluing up the layers of a sliced 3D object?
Seppy
Model of CNC Machine: 3 axis Router 1500mm x 4000mm Bed
Re: Slicing and gluing
Post by Seppy »
Hi Angelo,
That's a very general question, you may need to be a little more specific.
Do you have a project in mind? What kind of shape, is it small, large, gigantic? Naming the material you are attempting to glue up would be a good place to start.
People around here are very helpful, so the more information you can give, the more relevant the help you will receive :)
Rick
zeeway
Post by zeeway »
If the question is how to maintain alignment during glue up...you could drill through for dowels in the same locations in each layer, and then, of course, use dowels for alignment.
Angie
graffix11
Model of CNC Machine: Two machines, CRP 48x96 and a xylotex
Post by graffix11 »
I think I also heard someone say they used a little salt to keep from sliding?
angelosart
I was basically looking at alignment of the pieces. I had thought of pins or dowels but I was just wondering if there were other methods people found successful. My project is the shark on the tutorial...this. My first crack at slicing.
cabnet636
Model of CNC Machine: CAMaster 508 ATC
Post by cabnet636 »
we use Nails and pins to hold and concrete sacks (hardened for weight on large pieces
James McGrew
http://www.mcgrewwoodwork.com
CAMaster ATC 508 24/7 http://dropc.am/p/EJaKyl
GraClay
Post by GraClay »
So James....are you one of those strapping young lads shown in the earlier pics or the old codger holding the pneumatic wire wheel? :)
GC
cabnet636
Post by cabnet636 »
I am in none of the pics
James McGrew
