Adding a new tool ..Cutting Parameter settings ?
Roy50
Model of CNC Machine: cnc3040
Post by Roy50 »
Hi
Sorry if this is a dumb question ..I am totally new to this and don't want to make a mistake during my learning curve or I will not know what to blame it on :-)
I am trying to add a new tool to the database.
The tool is marked V .40 4 I assume that's V bit 40' angle 4 mm shank
I am ok how to add a new tool option, I copied an existing V tool - V-Bit (60 deg 6 mm) - and have edited/input the above info
..but is ok to keep the original Cutting Parameters and Feeds & Speeds from the copied tool ? or do different tools need different parameter settings ?
I will just be routing timber
Roy
Re: Adding a new tool ..Cutting Parameter settings ?
Post by TReischl »
The bigger question is:
What do YOU think of the cutting speeds and feeds?
Nevermind what someone else set them at. The reason is that whoever set up the initial speeds/feeds did for THEIR machine, not yours.
You need to find out what your machine is capable of, not rely on someone else's settings.
Don't be afraid of making a mistake. If you are worried, you can always cut air and see how it looks to you.
One thing, cnc routing is nothing like hand routing, typically a machine can cut much faster than you would by hand. For instance, typically I run a .25 dia end mill .25 deep at 250 inches/min. That is full width of cut, btw. In wood, including hardwoods.
Roy50
Post by Roy50 »
Thanks carve wizard
I have so much to learn. I have been looking for an Idiots Guide To CNC for clues but it seems Trial and Error is the way forward.
Having an IT background I am used to fixed rules ...seems this industry doesn't have any so I have to reset my thinking.
