I must be doing something wrong in Aspire 4. Trying to make a simple picture frame, but there is no more check box for "connect rail nodes"...and this is what results. What am I doing wrong? (start points are both in lower left corner).
Angie
ps - well it seems to work as a single rail sweep (extrude)...but since I want to control the outer and inner dimensions, that is not what I want. Can it work as a two rail sweep?
Need help two rail sweep
- zeeway
Re: Need help two rail sweep
Hi Angie,
After you place the profile across the first corner, right click on the profile and select 'Add to All Rail Nodes.'
It was good seeing you again in Columbia.
Tim
Tim
- zeeway
Thank you Tim. You were exactly right (as usual ). Good to see you at Jim's as well.
Angie
Angie
