edge profiles
H2O
Model of CNC Machine: IronMan XE3624-Servo
edge profiles
Post by H2O »
I’ve been playing around with the demo program. I would like to build a corner bead tool to use for an edge profile. I haven’t been able to build a corner bead tool – any suggestions
How do I build a tool that will step horizontally?
Turtle49
Model of CNC Machine: 4' EZ-Router and Blurry customs SK25
Re: edge profiles
Post by Turtle49 »
Aspire does not allow you to build tools in the database that have under cuts. To do what you want you would have to use a dummy tool and set up the toolpath to accomplish what you want. You will also not be able to preview the toolpath to see the bead either.
Hope this helps,
Tim
Tim Hornshaw
www.HornshawWoodWorks.com
H2O
Re: edge profiles
Post by H2O »
Thank you for your reply. I would like to know how to build a “dummy tool” and how to increment the steps to go along the x or y axis.
Re: edge profiles
