align along vectors
mezalick
align along vectors
Post by mezalick »
Greetings,
Is there a way to "Copy Along Vectors" so that the item, be it a vector or a component, will align in a radial fashion, as in the pictures?
Thanks in advance.
Michael
Michael Mezalick
mm@mezalick.com
gravirozo
Re: align along vectors
Post by gravirozo »
michael
try to turn horizontal, or vertical position the part you want to copy along...
i made earlier two post, about chain and about rope...
http://www.vectric.com/forum/viewtopic. ... 91&p=68085&
about chain
and about rope
http://www.vectric.com/forum/viewtopic.php?f=2&t=6444
when i drew this rope i found the part need to be aligned horizontally or vertically that way will be each copied part in rigth direction
viktor
gravirozo
Post by gravirozo »
michael
im not sure you see objects will be copied with their center along on a vector
so if you like to stand these triangles, then you need to make an offset, with a value tha triangle heigth per 2
and youll copy on this auxillary vector the triangles, or spikes..
that way the triangles will standing on the wector originally you wanted...
mezalick
Post by mezalick »
Thank you Viktor,
Sometimes it's the simple things that I stumble over.
Michael
Michael Mezalick
mm@mezalick.com
gravirozo
Post by gravirozo »
red line is the auxillary vector
