aspire rises to the challenge!
rej
Model of CNC Machine: 2014 roc-tech 4x8 with servos
Post by rej »
recently this rope was posted on another forum showing the power of a competitor.
it was done with a feature we don't have, per sey, an extrusion feature.
so me being me, i had to try to duplicate it.
i tried a few times with no success, but i have a secret weapon - routnabout.
so i emailed a pic to him, and wahlah, he did it easily with a two rail sweep.
don will be at my camp in june and he will be showing how he did this with the distort feature.
sometimes its not what you know, but who you know! if you get stuck, send him a pm.
rej
http://www.3dsigncamp.com
http://www.roctechusacnc.com
esteeme1
Model of CNC Machine: Cobra 404 ATC; ROMAX WD-1; Shark
Re: aspire rises to the challenge!
Post by esteeme1 »
Rej,
very nice! and yes it is a challange. I won't share how I did it (don't want to spoil your fun). I will say this I did use a two rail sweep but it wasn't easy (for me).
Jim Darlas
"Can Do!"
http://www.esteemedwoodcrafts.com/
http://www.esteemedplaques.com/
esteeme1
Post by esteeme1 »
Now that the sign camp has concluded can you share the rope twist technique? I'm very interested and have been quite patient. :D Thanks
Jim Darlas
"Can Do!"
rej
Post by rej »
i will see to it that don gets this. he can explain it better than i.
kilrabit
Post by kilrabit »
I had a few minutes and made another version with Aspire.
Roy
rej
Post by rej »
kilrabit, can you share that file?
kilrabit
Post by kilrabit »
Rej,
The file is bigger than 5 meg, it is about 8 meg. If you want I can email it to you, a good TIF, is about 7 meg, and a .bmp is about 146K zipped, i will shrink it down to 6 in and post it here. If you get the CRV file you can see the single segment drawing, then you can sculpt the single segment, then circular array it to get the final rope. When it got baked it his the sculpt part, but is just using the add at full strength, with a small circle, and make a pass at an angle on the smooth segment.
Roy
6 in rope.zip
(145.18 KiB) Downloaded 207 times
esteeme1
Post by esteeme1 »
Hi Roy, Thanks for the reply. That's a nice rope, I was hoping to learn the technique. Would you mind sharing that? I'm just trying to improve my modeling skills.
Thanks for the help.
Jim Darlas
"Can Do!"
RoutnAbout
Model of CNC Machine: 24x18 Desktop
Post by RoutnAbout »
Hey Jim,
Create a new file at the resolution of your choice.
Import your bitmap. I then center the image in the material. (makes things easier when you go to circular array your component)
Once oriented. I created a closed vector the shape of one of the wires.
create a closed vector the shape of one of the wires
Then I created a circular array of the vector. You'll have to experiment with the number of items to get the look your after. Slightly overlapping the vectors. (this will give you an accurate number of components - once I know the quantity for the array, I delete all the close vectors except the one for the component)
Use the node editing feature to adjust the closed vector shape so the components will overlap slightly
Using the Create Shape and the closed vector you made, create your shape, again to your height that fits your need.
Once the component is created, use the Array Copy. (Remember centering the bitmap image - This will help because it will array the component around the center of the material).
Now you have the wire rope. Bake your components and then play with the height of the baked component.
Hope this helps.
Roll of Honor <-- Never Forget
________
Don
RoutnAbout
File attached
wire rope.crv3d
(1.97 MiB) Downloaded 265 times
________
Don
esteeme1
Post by esteeme1 »
Thanks Don,
I think my approach is way too over thought (as I do quite often). I'll share it anyway because I think I found an interesting effect. Will need some time to expain though.
Thanks again
Jim Darlas
"Can Do!"
kilrabit
Post by kilrabit »
Rej,
Since quite a few people have asked about the rope. I put one segment. Posting 26 segments was more than 3 meg, and could not post it. Here is how I did the rope.
Here is the file with only 1 rope vector, and one model segment. Your rope picture, had 26 strands, so just choose the model segment and choose 26 in the Circular Array and it will be assembled. Right click components, or group all of them together, one and choose merge. You can see that there is a lot of overlap, but you have to remember that you are drawing in 3D. When you visualize the rope in 3D, you will see that you only see about 30 to 35 percent of the rope strand. You still have to draw the whole strand, then overlap it just as the rope is made, and you will get a pretty close rendition of the rope. A lot of times if you draw what you see, it does not always turn out exactly as intended, you will get artifacts, or something just a little different.
Roy
Rope Vectors.crv3d
(320.5 KiB) Downloaded 214 times
