I was sloppy and only used two dowels, and ruined a work piece in the process
Learning by doing
How did you ruin the workpiece? Flipped the wrong way maybe? if the dowels are tight then you can get away with using 2 dowels but there is still room for a little movement, with 3 there is absolutely no movement & obviously no chance of flipping the wrong waymickecarlsson wrote: ↑Sun Nov 19, 2023 3:13 pmYes, today I found out (the hard way) the reason you need three (3) dowels for a double sided job.
I was sloppy and only used two dowels, and ruined a work piece in the process![]()
Learning by doing![]()
