Need help please
patriotcustoms
Need help please
Post by patriotcustoms »
Hi
I just received my Aspire DVD about 3 days ago and haven't stepped away from my computer yet, this is a great program, and an even greater value.
I am creating a clock for a xmass present and I'm having a small problem just wondering if someone can help.
I imported a 3D vector art dished model and created a boundery around it. I open up the tool path tab and set my material thickness, set up a roughing tool path and then a finishing tool path. When I preview it, the model is .125" below my material top, the highest part of the model is still .125" below, I would like the top of the model to be at the top of my material. I can't seem to figure this out. Please excuse my ignorance but this is all new to me.
Thanks for your time.
Turtle49
Model of CNC Machine: 4' EZ-Router and Blurry customs SK25
Re: Need help please
Post by Turtle49 »
Take a look at the "setup material" button.
Play with the "model position in material" slider to move the model up and down within the material.
Hope this helps,
Tim
:D
Tim Hornshaw
www.HornshawWoodWorks.com
patriotcustoms
If I change the position it will only go lower, if I slide it all the way to the top it's still about an 1/8 or so lower, if I slide it down the model just goes deeper into the material.
I have attached the the clock, you can see how the 3D images are below the surface.
CRFultz
Post by CRFultz »
You can make a circle around the center component (the bitmap) and make a planer shape from it with a height greater then what you currently have, that will raise it up. Make sure you place it at the top of the list in the Component manager.
