First: Thanks to all those who post on this site - I have learned a lot from your expertise.
The problem: I can import a 3D file (shape of a house from SketchUp), scale it, roughly position it, and adjust the zero plane but run into 2 problems.
The first problem is manipulating the 3D object. It seems to want to pivot off of one corner which makes alignment difficult. I am trying to get a clean diagonal slice so I can see the front and one side looking at one corner. What are the "tricks" to controlling the roll of a 3D object?
Second, sometimes when I click OK I get the right shape into the 3D view. Other times I get what can best be described as a long stick shape which bears no relation to any part of the 3D object.
Many Thanks to any advice!
Importing 3D files to ASPIRE
Cobblewood Carver
Re: Importing 3D files to ASPIRE
What I do is use the Top Surface selections to get the correct face aligned with the plane. Then I adjust the model size to whatever I want it to be.
Then I use the Zero Plane Position slider to get that face roughly aligned with the plane.
Finally I use the shift-Left mouse drag combination to position the model with the correct tilt.
I find the last stage really difficult and it usually takes several attempts. I think it's just one of those things that takes practise, I'm not sure I'll ever get the hang as I do 80% of my work in Sketchup and I'm too used to using my left hand on a 3D mouse.
- BrianM
- Vectric Staff
A common mistake is to forget to press the apply button after changing the size of the model.
Thanks for the tips. Resizing is not a problem. Controlling the tilting of the object is like herding cats! Can anyone tell me why I get the "long stick" figure when I finally select OK sometimes instead of the part of the model above the zero plane? Is it because Aspire cannot handle a negative or hidden space?
Cobblewood Carver
