Long time owner of Aspire, but have not used the software in a very long time.
I need to cut several angles to be used by a disc sander. They should only be 1.5" to 2" on the longest side of the triangle.
I need 20 degrees, 20.1 degrees, 20.2 degrees, 19.9 degrees.
Can anyone point me in the right direction to learn how to use Aspire to do so?
Thank you.
Angles?
Re: Angles?
The Rotation tool lets you type in an exact angle to rotate a line by. You can also use the Polyline tool and specify the angle when drawing but I find it easier to draw a straight line and then use the Rotate tool.
- Model of CNC Machine: Avid CNC
Re: Angles?
