I am importing some SVG files from a Carbide Create project. When I import the vectors, they are larger in Aspire than they are in the other software. I can get them pretty close by just resizing them, but I would like to make them exact. Is there a way in Aspire to directly type in the x and y dimensions of an imported vector?
DQ
Exact sizing of an imported SVG.
- Model of CNC Machine: Home Made Desktop
Re: Exact sizing of an imported SVG.
They should be imported at the correct size.
Under transform objects, second icon on top row, set selected objects size
Thank You very Much!!!
DQ
DQ
Generally speaking when I hear of things being "much larger" I suspect this: the original is in millimetres and the project being imported into is in inches.
When you scale the vectors does it say that the new size is 3.937% of the original?
