create drawing and import to create model
- Model of CNC Machine: Carve King
What do some of you use to draw your creation and then take that and import into Aspire. Do some of you draw on a tablet and import that drawing. do some of you just draw on paper and scan that into your computer for Aspire.
Re: create drawing and import to create model
I draw everything directly in Aspire. The toolset is more than good enough to do everything I need so I don't use external programs at all these days.
When I first started I used Sketchup and exported/imported DXFs (there was no direct Sketchup import in those days. That was purely because I was far more proficient with the toolset of Sketchup than I was with VCarve/Aspire.
Use whatever works best for yourself, that is what most people seem to do from what I have read.
You have the drawing tools to create artwork within Aspire so if you don't have a vector-based software that you are very familiar with then you may as well learn to use the tools within the software, you will get much cleaner vectors working that way.
I don't currently have a working tablet so no personal experience using one with Aspire but I believe Aspire works with a range of different brands so again use a tablet directly with Aspire rather than some other software.
If you have a tablet or are considering buying one then there is no need to draw on paper, scan & import
I have used a lot of Cad and Cam over the years.
I use Aspire to draw, create models, and generate code.
I find it all integrates nicely
You can use a digitizing tablet with Aspire
