Help please. . . Box Gadget
- Model of CNC Machine: Alpha CNC 6090 with 4th Axis
Hello all,
Has anyone seen this error before?
Do you know how to overcome it?
Re: Help please. . . Box Gadget
I'm on the latest Aspire version. I've used the Box Gadget a few times before and love it.
Now I really need to use it and it's failing.
This is what I'm after.
But I'm only getting 2 of the sides and the base before it fails.
Here's my CRV file.
Can anyone help me please?
Thanks in advance.
Jim
Thanks in advance.
Jim
- Drawer Under Sink (Extra Wide) (500) Full Depth.crv3d
- (471 KiB) Downloaded 12 times
Try increasing the size of the material. Others have reported that this error can come up when the material isn't big enough to hold all the parts. I haven't had it do that myself but it's an easy enough change to make, you can always reduce it afterwards.
Thanks Adrian. I'll try it now.
It's not been a problem before so I didn't even think of that.
Jim
Jim
Nope!
That Didn't do it.
Jim
That Didn't do it.
Jim
All I can suggest is tweaking the settings you're using until it works. The error is thrown when a certain loop in the code goes on for more than 10 times.
Ah!
I can understand that.
" Ever decreasing circles"
I'll be tweaking my settings tomorrow then.
Thank you Adrian.
Jim
Thank you Adrian.
Jim
Thanks Adrian,
Cor! What a Pullava!
Right. It wouldn't allow me to do the ends.
I managed to do one end and run it again to do the base & sides.
Just need to copy the one end and move it onto my sheet and I'll be away.
It's been interesting as I now have a better understanding of what's going on.
Cheers.
Jim
Cheers.
Jim
Quick update:
I'm starting to get the hang of it. I'm creating all of my parts and using my max sheet size I can work out how many 8' x 4' plywood sheets I need. Got to do it quickly to order the ply. I've just been asked to do some CAD work so the drawers have to wait. . . . . . which doesn't make the planning dept. happy. (Mrs. Jim)
Big learning curve but very happy with Aspire.
Thanks Adrian for your help.
Jim
Jim
