We do a good bit of Vector Texture woodgrain signs in 3/4" pvc.
Sometimes i get "poc marks" in the woodgrain.
Some i understand, when the 1/4" ball squeezes' into a tight spot with only a z move available between letters.
But, sometimes it makes a pm in the woodgrain where there is no nearby contours to deal with.
See pics below.
I'd apricate any feedback to correct the issue.
thank you
Roy Shimp
904 268-3335
Poc marks in woodgrain
- Model of CNC Machine: Axiom AR8 PRO V5
Re: Poc marks in woodgrain
With not knowing how many things you may have tried there are a few variables that come to mind you could try,
The pattern goes right up to your border you might try to stay away from the border to lessen those edge pock marks,
The texture menus have a longest and shortest stroke length you might try and lengthen the shortest stroke,
Try various combinations and zoom in on the tool path preview to check your work,
Do the marks show in the toolpath preview?
- SteveNelson46
Is the image imported? If so, then check for extraneous or stray pixels where the pock marks are. You may need to drag select a large area then zoom in really close on the 2d screen.
Todd- I'll look at stroke length.
thank you
thank you
Steve - I'm embarrassed to admit, i didn't think about that....
thank you
thank you
Martin - Like i posted to Steve, it's silly, i didn't check the toolpath very close. i will do that.
thank you
thank you
