I was working on some underdash "classic" car replacement parts and found out that when I went into 3d mode I couldn't (ctrl Z) Undo anymore. went back to my saved file in 10.514 and I was able to do the undo feature. is this the new way of working on version 11.5? And is there a work around other than me saving each time I try to sculpt, cut model or merge parts in Aspire?
thanks
Undo in 3d modeling mode.
Re: Undo in 3d modeling mode.
Ctrl-Z is working ok for me when sculpting in 11.504
Could you explain your workflow to see if it's a generic problem or something specific to your setup?
I was having the same problem. I just discovered that I left the Materials Setup panel open in the tool path section. Once I closed that panel, Ctrl-z & undo were working again
