I am running the new version of aspire 11.503. Has the Feed rate changed?
What I mean is...
Before... I used have the tools setup, and based on my chipload and tool parameters I would obtain my feed rate.
Now it seems the speed is automatically calculating the feed rate ... can I now assume it is corrected based on my chosen speed?
Maybe it was always doing this? Just wondering...thanks.
Ok, I think I may be losing my mind...!?!
Re: Ok, I think I may be losing my mind...!?!
The chipload field is just a display calculation based on the feed rate, spindle speed and number of flutes.
If you change any of those three parameters the displayed chipload will change accordingly.
Adrian, thanks for responding...
I guess what I'm asking is....was the calculation always automated?
I don't remember the feed rate automatically changing before. So I was just trying to figure out if all this time I had been changing it when I didn't need to.......
- Leo
How is the FEEDRATE changing automatically - it should not be.
The CHIPLOAD will change automatically when you change the feedrate, but not the other way around.
So what I would do, go into the tool setup...
Set my speed, look at the chip load. Then I would go to Precisebits speed and feed calculator since I use their bits.
I would enter the spindle speed, diameter, and chipload. Their calculations would give me the Feed speed.
I would then enter it into the toolpath setup.
Now as soon as I enter the spindle speed, it calculates the chip load, and populates the feed speed. I don't remember it filling in the feed speed previously... that's why I think i'm losing it! lol...
anyway, it was really confusing me, because if you change your feed speed, the chip load changes... AND i can modify the chip load...
I feel that I shouldn't be able to do that... because I feel like the numbers are then arbitrarily created by me...
Make sense?
I liked it when there was a control involved...
Make sense?
As has already been said those settings are not automated, you set the spindle speed & the feed rate yourself, you can't set a figure for the chipload yourself by typing something in the box but if you change either the spindle speed, the feedrate or the number of flutes then the chipload will change
There haven't been any changes to how it all works with the 11.503 patch
I'm struggling to understand this. The indiscriminate use of the pronoun "it" isn't helping.
A pictorial essay:
Tests done in VCarve version 11.501. Perhaps automatic updating of the other field happens when you alter the spindle speed or feed rate in versions 11.502 or 11.503 but that seems unlikely as VCarve has never done that in all the versions I've used.
A pictorial essay:
No nothing has changed in either 11.502 or 11.503 of Aspire
