Text
Text
When I put font on a wood I use a 60 degree V bit. It always looks "too deep". If I adjust the height it becomes unreadable on the project. I want the look of "drawn on" not "carved in" hope that all makes sense. Any advice?
Re: Text
Lots of options but only you can tell which one is the look you want.
A single line font with a profile toolpath set to be On the vector with a small ballnose will give a more drawn look.
You could also experiment with the v-carve toolpath with v-bits and ballnoses with a shallow flat depth. You could use non-single line fonts with that.
That's just two ideas out of many.
