Keyboard shortcut chart
- revwarguy
- Model of CNC Machine: homebuilt
Has anyone done a keyboard shortcut sheet for either Vcarve or Aspire? After some searching, I saw someone mention a page from the help file pdf, but I didn't see that either. The help file with the product (i.e. F1) does not have page numbers. Anyone have a printable keyboard cheat sheet?
Re: Keyboard shortcut chart
Keyboard Shortcuts: ->Link
Help Menu > Keyboard Shortcuts. That opens in a browser so you can print from there using normal browser print commands. Page numbers are part of that if you really want them.
- Model of CNC Machine: Shapeoko3
I find that link to the Keys somewhat useful.... but I also find that I like a simple shorter print-out (instead of 63 pages):
You can format this as you wish....or convert to pdf etc
- Tex_Lawrence
- Model of CNC Machine: Shapeoko3XXL; JTech7W; V-CarvePro 12.013
Under Node Editing, below X is some foreign language text.
Tex — Crooked Wood Products
- scotttarnor
Changes the X coordinate position of selected nodes to match the position of the first (when multiple nodes are selected
Scott T
@scottscnc
@scottscnc
- Model of CNC Machine: Custom router with Dynomotion KFLOP
Ok, I'm reviving this thread since I'm just back from the 2022 UGM (fantastic meeting!!), and once again realizing I only use about 10% of the keyboard shortcuts.
So... I went looking again to print out a simple "cheat sheet" of the keyboard shortcuts, maybe two-sided, that I can laminate and keep on my desk.
The shortcuts list for V11 layout is even worse for printing out, 22 pages for me when I preview it as a PDF to print.
I went back to look at the last one I printed, for V10, a mere 10 pages, and the layout was much more condensed, but no where near something that would fit on a double-sided, laminated real-world cheat sheet.
A "cheat sheet" doesn't have to have the long explanations of the documentation, so it could be condensed into a couple columns on each side, with brief hints for what a key means, and the syntax for things like the equal sign (I use other software so I routinely screw up whether the equal sign is first or last, e.g. trying to enter a little less than the Z thickness in a toolpath... Z-0.02=). The full docs are easy to access from Aspire if there is any confusion on a specific shortcut. The cheat sheet is just a memory-jogger / reminder for the less frequently used ones, and specific key order or modifier keys.
Before I dive into trying to layout a more condensed one, has anyone created a keyboard shortcuts PDF cheat sheet? Or taken a stab at it? Or ???
Cheers,
--Jon
Cheers,
--Jon
Slightly edited version of hooby's .xlsx file above, with translated text...
If no one else has made progress, I may use the Excel file as a starting point.
- Vectric_key_shortcuts_v2.xlsx.zip
- (13.36 KiB) Downloaded 225 times
- Model of CNC Machine: Onefinity Journeyman X50
How did your efforts come out on this? I just started diving into vcarve and don't really want to have to make my own campbell's condensed version if someone has done it already
Chris
Chris
Started with Vcarve Pro Mid July 2023
Using OF Journeyman x50 Aug 2023
Bets to use the "official" Keyboard Shortcuts on the Help menu IMO. All the info is there and always up to date.
- Model of CNC Machine: I2R A24
Here is a PDF shortcut document for Aspire v12 which when printed 2 to a page and double sided produces two pages
- Aspire V12 keyboard shortcuts.pdf
- (156.84 KiB) Downloaded 97 times
