Windows xp not accepting aspire 11
- Hurricane
- Model of CNC Machine: K2 4 axis
I use an older pc for running my CNC and it runs on parallel port. aspire 11 will not load to windows xp. any help????
"Whitey"
K2 Devices/4 axis
Corel Suite
PhotoCarve
Aspire11.0008
K2 Devices/4 axis
Corel Suite
PhotoCarve
Aspire11.0008
- ohiolyons
Re: Windows xp not accepting aspire 11
Is it 32 or 64 bit XP?
Did it run before?
I think Vectric no longer supports 32 bit versions of your OS with 11.
Did it run before?
John Lyons
CNC in Kettering, Ohio
- ohiolyons
Looks like they no longer support XP
John Lyons
- IslaWW
The 80's called, they want their operating system back.
Seriously, micro$oft doesn't support it, highly unlikely any software developer would. Why I the world would you want to use an OS that old?
Gary Campbell
GCnC Control
GCnC411 (at) gmail.com
GCnC Control
- TomWS
- Model of CNC Machine: OB Lead 1010, Mach3; OB C-Beam 1060 grbl
Well, it probably runs pretty darned fast! About 5 years ago I was 'retiring' a couple of old laptops that were occupying space in my closet. On a lark I decided to fire one up, just to see if it still worked. In a flash I had Windows 3.11 up and running, ready to dial out on the 9.6K modem! It wouldn't connect to my WiFi network so I trashed it.
However, even I wouldn't try to run anything later than vintage 2010 SW on XP.
At home I run XP on VirtualBox under macOS just to run VCarve 9.5. It's warping fast compared to the multi-core multi-processor super GPU Windows 10 machine on my desktop at work...
Iona doesn't support my 60 year blender but it works just fine thank you.
