Help converting an old file
I have an old file that I made in Aspire 4 many years ago. I no longer have Aspire, but have the new version of V Carve Pro. I was hoping someone could convert the file to use in V Carve. If that's possible, I'd attach it to a PM. Thanks
- jfederer
- Model of CNC Machine: CanCam D23M
Re: Help converting an old file
Anyone else able to help? I got the file from Rod via DropBox, opened it without problem in Aspire 11.008. Then I tried a straight save to CRV, but the Component didn't save. Then I tried a DXF export, but when opened in VCarve, it was blank. Then I tried an Component Clip export as 3dClip. No joy there either.
The file is for a baked single-component chair seat with some additional 2.5D areas.
Someone with more experience?
Joe Federer
www.federer.ca
www.federer.ca
Thanks to Joe for trying. Here's the dropbox link:
https://www.dropbox.com/s/393ef9gapdjgw ... crv3d?dl=0
- ohiolyons
your vcarve version will have to match what ever version of aspire converts it to a crv.
the components (models) if any will have to be exported as a STL, you would then have to import that STL.
John Lyons
CNC in Kettering, Ohio
- SteveNelson46
I'm not sure if you can import a .3DClip file but here is a link.
https://drive.google.com/file/d/1junBJK ... sp=sharing
- ohiolyons
3dclip only work with Aspire. That is why I said export as a STL from Aspire and Import the STL in Vcarve.
John Lyons
- SteveNelson46
Well then here the link to a .stl file. All of my clipart files that came with the program have a .3dClip extension so I just assumed V-carve can read them.
https://drive.google.com/file/d/1jvDVra ... sp=sharing
Steve:
Outstanding. Thanks very much. It works as an import in V Carve. I appreciate it very much.
- SteveNelson46
