Can anyone tell if our money from 2020 is going to rollover to 2022.
If shows that it rolled over from 2020 to 2021 but not to 2022
user group 2022
Re: user group 2022
That would be a question for Vectric support rather than the forum which is mainly user to user
Sure someone from Vectric will step in at some point though & give an answer.
If you read the 2022 UGM announcement there is a bit at the bottom about Vectric extending their refund policy until may 2022 which may indicate that it will roll over again but obviously only Vectric can tell you exactly how things stand
- Model of CNC Machine: Legacy 3x5 cnc
Re: user group 2022
Thanks Martin,
I thought that someone on the forum might know.
I will email the vectric directly if I don't get a reply on the forum pretty soon
Thanks again
Thanks again
- gkas
Re: user group 2022
I contacted Vectric..... Mine DID roll over from 2020 to 2021 to 2022. I think it depends on what you responded to as refund options. I had a very fast response from support.
- Vectric Staff
- Model of CNC Machine: xxx
Re: user group 2022
Hi Stan,
Thank you for your message.
I can confirm your UGM reservation from 2020 has been moved across to 2022 automatically - so you don't need to do anything.
If you require a hotel room for the duration of the event you will need to book this again here: https://book.passkey.com/event/50252115 ... 10710/home
I hope this helps.
Stephanie
I hope this helps.
Stephanie
