Is it possible, to duplicate a sheet with all elements incl. toolpath?
Or copy a toolpath to another sheet?
I've many sheets with different designs, the toolpath goes with different layers.
I don't want do redo every toolpath manually.
Thank you
Aki
Duplicate sheets / copy toolpath to another sheet
Re: Duplicate sheets / copy toolpath to another sheet
If you have the toolpaths setup with layers and automatic vector selection then the toolpaths will be created on the other sheet automatically when you press the Recalculate All button.
Depending on your chosen workflow you may need to change the value of "Select Sheets when Edit Toolpath" in Options.
You can also export and import the toolpaths as templates which will give you the option to create all toolpaths on all sheets at the same time if they have been set up with layers and association.
Look at the Mass Production section in the tutorial videos for more information.
This works. Thank you!
