been trying to make a 3d model by splitting the first in half then want to be able to set each side to a double sided machinable model
trying a dog model (obj) and want to machine the material from between the legs
splitting a 3D model into 2 double sided models
- ohiolyons
Re: splitting a 3D model into 2 double sided models
What kind of model (STL, Vectric clipart)?
If it is an STL vectric has enhanced importing options for STL and you should watch that video.
Not certain why you would want to split and do multiple 2 sided?
John Lyons
CNC in Kettering, Ohio
- Model of CNC Machine: Shark HD4
john i dont have 4th axis and cant spin model and carve
i have a OBJ,STL greyhound trying to split down middle left side right side then be able to do double sided machining on each half
problem is it joins the legs together into one the front and back
Due to the way Vectric products handle 3D objects (no undercuts hence the joining of the legs) you will not be able to this from within Aspire.
This will need to be done by an external program such as the one used to create the STL/OBJ files. Windows 3D Builder (might be installed on your machine already) might help but I've never used it. https://www.microsoft.com/en-us/p/3d-bu ... verviewtab
- jfederer
- Model of CNC Machine: CanCam D23M
You might want to watch the segmenting presentation from the UGM. I think you can do what you want using the techniques described there. You'll need to get creative, but it should be possible. https://ugm.vectric.com/session/3d-segmenting
Joe Federer
www.federer.ca
www.federer.ca
