Cutting issue must be operator error
ohiolyons
Post by ohiolyons »
The attached file has vectors on it.
I can use the interactive trim on the closed vector marked by "1". As it should.
I can use the interactive trim on the lines marked by "2-4". As it should.
I can NOT use the interactive trim on the line marked by "5".
Lines 3-5 are just copies of 2.
I'm certain it is me, but help!!!!!
LE-1.crv3d
(46.5 KiB) Downloaded 39 times
John Lyons
CNC in Kettering, Ohio
Re: Cutting issue must be operator error
Post by martin54 »
I've just had a quick look & no idea just now why it won't work on Line 5 but strangely if you right click on it & use the convert to curves tool after doing that then it does work the same way as the other lines :lol: :lol: :lol:
ohiolyons wrote:
Sat Oct 23, 2021 9:01 pm
The distortion for line 5 has not been baked. When you select it you can see the transformation box around it and if you bring up the Distortion tool you can see Edit Envelope options are still active which also indicates that it hasn't been baked.
ohiolyons
Post by ohiolyons »
Knew it was Operator Error Thanks.
Thought I backed out of the distort, guess not far enough.
John Lyons
