Hi All
I can't seem to open any clipart with V11...
any ideas
Clipart missing
- SteveNelson46
Re: CLIPART MISSING
Two step process. Go to your portal account and download each clipart installer to a folder on your computer. Then run each installer. It will place the clipart in the approiate locations for the program to use.
Re: CLIPART MISSING
You should be able to see the previews in the Clipart tab without downloading the package though. When you try to use it then it will ask to connect to your account and download just that one item.
Is that not working for you or are you trying to open the clipart in some other way?
- Model of CNC Machine: AXYZ 4008 Series, LASER CUT 1390 120W
Re: CLIPART MISSING
Thanks! still can't see the clipart and can't see where they are in the portalSteveNelson46 wrote: ↑Fri Oct 01, 2021 6:34 pmTwo step process. Go to your portal account and download each clipart installer to a folder on your computer. Then run each installer. It will place the clipart in the approiate locations for the program to use.
Re: Clipart missing
Some images to help. Check captions for details:
