Good Afternoon Forum,
I am seeking some help again. I want to cut the free DM emojis. I have some scrap clear pine that is about .75 inches thick.
I have imported the emoji files. I can get the emoji file into the modeling tab. My difficulty is deciding how thick the base should be and the model height . So I settled on .20 for the base height and overall height of .53 for the project. I want to set the Z height to table base.
My difficulty is cutting the emoji out. I seem confused on how to set up a profile cut on the border of the emoji. It is not a perfect circle. The sunglass edge sticks out a bit.
I also do not under stand the message when run the 3d finishing program that states Large Machining Allowance selected.
Not sure what this means. I am also wondering what to set the rest Machining to. I would like to not have to sand to much.
Any advice or tips and help is greatly appreciated.
Help with Emoji Project
- Happy E.crv3d
- (1.74 MiB) Downloaded 43 times
Re: Help with Emoji Project
Select the 3D model, go to the modeling tab at the top of the screen, on the dropdown list select create vector boundary for selected 3D model
This will create a boundary vector for the model.
- SteveNelson46
Machining allowance on the roughing toolpath is how much material is left for the finishing toolpath to remove. If it exceeds more than 20% of the tool diameter, in this case .025" or 20% of a 1/8" endmill, then you will get the error message.
I really don't think you need rest machining on such a small project. Your 1/8 em in the roughing toolpath has already done most of the work. Delete the 1/8" EM in the finishing toolpath and it should be good to go. If you really need that much more resolution on the finished project try replacing the 1/8" end mill in the finishing toolpath with a 1/16" ballnose. You could even add a 1/32" ballnose for a smoother finish. Successively smaller bits will produce an even smoother finish.
