Stepover Retract
- Hurricane
- Model of CNC Machine: K2 4 axis
Stepover Retract
What is the advantage of this function???
"Whitey"
K2 Devices/4 axis
Corel Suite
PhotoCarve
Aspire11.0008
K2 Devices/4 axis
Corel Suite
PhotoCarve
Aspire11.0008
Re: STEPOVER RETRACT
Copy and paste straight from the help file:
In the Finish Machining Toolpath form a Stepover Retract Value can be applied to the Offset Machine Strategy. If the value you enter is greater than 0 then the tool will lift off the surface of the composite model by this amount when stepping between each offset contour. Depending on your material and tooling, adding a small lift will eliminate perpendicular tool marks between the toolpath contours to potentially improve the finished surface.
- Hurricane
thanks just wanted to be sure that is what would happen...
"Whitey"
K2 Devices/4 axis
Corel Suite
PhotoCarve
Aspire11.0008
K2 Devices/4 axis
Corel Suite
PhotoCarve
Aspire11.0008
- scottp55
Re: Stepover Retract
Before we had Stepover Retract, notice the diagonal lines here;
I most commonly, use a .01" retract personally now.scott
R.N.
R.N.
