Hi
I have tried v carving a chechered emblem and also with pocket toolpath same problem occurs, i used a friends ver 9.5 with a 20deg engraving bit with succes cutting to lines but when i purchased ver-11 it will not let me cut to the line it cuts short as i need cut every alternate square and come back the following day and cut the opposite squares. thanks in advance
regards marko
v carve and pocket toolpaths not cutting to lines
Re: v carve and pocket toolpaths not cutting to lines
Have you got the bit correctly defined? You say it's a 20 degree bit but is that the total angle or the side angle? With an engraving bit you enter the side angle and with a v-bit you enter the total angle.
The previews (both 3D and solid 2D) are correct so you're either using a different bit from what VCarve has been told or there is another issue with your machine or process.
Hi thanks for that will change all engraving bits to v carve definition
If I understand what you have said correctly then entering your engraving bits as V bits is not a good idea (generally) because the software assumes a V bit comes to a point & doesn't take the flat into account which may give you strange results. What you need to do is make sure you have them set up correctly in the tool database.
As Adrian has pointed out V bits are entered using the included angle of the bit & engraving bits entered using the side angle of the bit (half the included angle)
Make perfect sense
- scottp55
Yep, to start enter bits exactly as they are for an accurate preview!
For instance, a VBit stepover is a percentage of tool Diameter.
An Engraving bit stepover is a percentage of the Tip Flat!
It can Muck up a cut in short order.
I Do have most of my small tip flats Engraving bits entered as VBits ALSO for exceptions,
BUT you have to have a picture in your head that it will cut deeper and shave the sides a hair.
Best to stick with an accurate tool description, so an accurate preview saves you a workpiece!
(Don't ask how I know!)
R.N.
R.N.
That's why I rarely think about step-overs in terms of percentages. I pretty much always think in terms of absolute distances (e.g. 0.03 inches) that way it doesn't really matter how the Vectric programs derive the percentage. An exception is hogging out large areas with large cutters.
It's fun seeing people say "I set the step-over to 1%" and you realize that it's 1/10.000 inch and you know that their machine's stepper motors only have a resolution of 1/1,000 inch so they're doing 9 passes with little effect.
