I've just opened a file in v11 that was open and edited 10 mins prior.
The list of fonts is now blank.
I have closed and restarted the PC to no avail.
If I open the file in 10.5 all the fonts are available in the list.
BUG - Font list empty in v11
Re: BUG - Font list empty in v11
You would probably be best to contact Vectric support directly about this, Vectric software uses the Windows installed fonts & doesn't have it's own font management, no idea why it should be working OK in one version & not another. Might require you install V11 again but I would check with support first. I've certainly never had any issues with fonts not showing myself in any version of the software.
support@vectric.com
support@vectric.com
Indeed, that's what I thought. Been using Aspire since v8 and never had an issue.martin54 wrote: ↑Mon Sep 13, 2021 12:27 pmYou would probably be best to contact Vectric support directly about this, Vectric software uses the Windows installed fonts & doesn't have it's own font management, no idea why it should be working OK in one version & not another. Might require you install V11 again but I would check with support first. I've certainly never had any issues with fonts not showing myself in any version of the software.
support@vectric.com
I will take it up with support if re-installing doesn't work.
- mtylerfl
Hi Matt,
Here’s a shot in the dark, but perhaps worth a try:
Try running your Vectric v11 software “as Administrator” to see if your font list then reappears.
Thanks for the input guys.
In the end it came down to user error!
